pioter83
Nov 30, 2022Aspirant
RR2312 UART serial console connection
Hello, trying to connect to UART serial console USB<>Micro USB. Have two cables, both with right drivers: 1) Chimera UART Cable FTDI 2) Octoplus micro UART Prolific USB to serial Step by st...
Sandshark
Nov 30, 2022Sensei
I have never seen anything that says any ReadyNAS uses any standard FTDI pin-out for the UART port. Everything I see on using it starts with figuring out which pin is which. There is also the fact that some ReadyNAS (mostly legacy units) use a 5V UART and some use 3.3V. I've not seen anything on which the RR2312 uses, and my 2312 is in storage, so I can't check. Connecting a 3.3V adapter to a 5V port will simply not work, while connecting a 5V adapter to a 3.3V port could do damage.
Hopefully, you just need to swap transmit and receive, as any other wrong connection could do damage. But I don't see how you would do that on either of those adapters.
pioter83
Dec 05, 2022Aspirant
You are right, but I wasn't. As I found "use any USB<>micro USB cable - I did so... got nothing... [solution just by now đ ]
Ordered two cables I found, people wrote about... none worked...
[solution] NOT "any USB<>micro USB cable" - be sure your cable provides DATA transfer... that's all!
PS. Info about making RR2312 an TrueNAS will provide tomorrow in different thread [will attach here]
