marshall_brown's avatar
Jul 27, 2010
Running Bugzilla - Webaccess required
HI all, I have managed to get bugzilla running after a few headaches with perl modules, now I would like to have it hosted properly on my readynas.
Any pointers on how to do this, I have added the following line in my /etc/frontview/apache/httpd.conf file
Include /etc/frontview/apache/bugzilla.conf
and created the file with the following contents.
<Directory /bugzilla>
AddHandler cgi-script .cgi
Options +Indexes +ExecCGI
DirectoryIndex index.cgi
AllowOverride Limit
</Directory>
yet I am unable to access it. I get
Forbidden
You don't have permission to access /bugzilla on this server.
Thoughts and suggestions are appreciated.
Regards
Marshall Brown
1 Reply
  • As I spent some time figuring out how to get Bugzilla running on the on our NAS (2100) I would like to share the actions I had to take to get it working.
    Again this is provided as-is. I had to install some packages which also upgraded existing packages so you probably loose support when you do this.
    Maybe someone can convert it into a supported add-on…
    I had to start from a factory default installation and upgraded to the latest release (4.2.21)
    Install official ReayNAS photos so MySQL is configured correctly !!!
    install build tools
    apt-get upgrade
    apt-get install build-essential
    Switch to lenny distribution in /etc/apt/sources.list
    deb http://archive.debian.org/debian lenny main
    Update keys
    gpg --keyserver pgpkeys.mit.edu --recv-key AED4B06F473041FA
    gpg -a --export AED4B06F473041FA|apt-key add -
    Retrieve aptitude as it resolves better the dependencies than apt-get (only way I could install libmysqlclient15-dev which is required by one of the perl packages)
    apt-get install aptitude
    aptitude update
    aptitude install libmysqlclient15-dev
    aptitude install libgd2-xpm-dev
    Switch to back to etch distribution in /etc/apt/sources.list
    deb http://archive.debian.org/debian etch main
    Install bugzilla
    useradd –g admin Bugzilla
    passwd Bugzilla (Choose your password)
    mkdir /home/bugzilla
    chown bugzilla:admin /home/bugzilla
    mkdir /c/.bugzilla
    ln -s /c/.bugzilla /opt/bugzilla
    chown – R bugzilla:admin /c/.bugzilla
    su - bugzilla
    cd /opt/bugzilla
    wget http://ftp.mozilla.org/pub/mozilla.org/webtools/bugzilla-4.2.1.tar.gz
    tar xvfz bugzilla-4.2.1.tar.gz
    ln -s bugzilla bugzilla-4.2.1
    cd bugzilla-4.2.1
    /usr/bin/perl install-module.pl --all
    ./checksetup.pl --check-modules
    Edit the localconfig
    $webservergroup = 'admin';
    $db_pass = 'bugs';
    $index_html = 1;
    Add the MySQL user
    mysql
    CREATE USER 'bugs'@'localhost' IDENTIFIED BY 'bugs';
    GRANT SELECT, INSERT, UPDATE, DELETE, INDEX, ALTER, CREATE, LOCK TABLES, CREATE TEMPORARY TABLES, DROP, REFERENCES ON bugs.* TO bugs@localhost IDENTIFIED BY 'bugs';
    FLUSH PRIVILEGES;
    SHOW GRANTS FOR 'bugs'@'localhost';
    Launch Install
    ./checksetup.pl
    Add Bugzilla as an addon to frontview Apache
    echo "Alias /bugzilla /opt/bugzilla/bugzilla" >/etc/frontview/apache/addons/BUGZILLA.conf
    echo "<Location /bugzilla>" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo "</Location>" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo "" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo "<Directory /opt/bugzilla/bugzilla>" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo " AddHandler cgi-script .cgi" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo " AllowOverride All" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo " Options +Indexes +ExecCGI" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo " Order allow,deny" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo " Allow from all" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo " DirectoryIndex index.html index.cgi" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo " AllowOverride Limit FileInfo Indexes" >>/etc/frontview/apache/addons/BUGZILLA.conf
    echo "</Directory>" >>/etc/frontview/apache/addons/BUGZILLA.conf
    chown admin:admin /etc/frontview/apache/addons/BUGZILLA.conf
    chown -R bugzilla:admin /opt/bugzilla
    Restart apache
    apache-ssl -f /etc/frontview/apache/httpd.conf -k restart
    Additionally setup polling of an email account
    apt-get install fetchmail
    apt-get install postfix
    echo "poll mail.xyz-c.com" > ~/.fetchmailrc
    echo " proto pop3" >> ~/.fetchmailrc
    echo " auth password" >> ~/.fetchmailrc
    echo " user \"bugreport\"" >> ~/.fetchmailrc
    echo " pass \"mypassword \"" >> ~/.fetchmailrc
    echo " is bugzilla" >> ~/.fetchmailrc
    echo " keep" >> ~/.fetchmailrc
    echo "\"| /opt/bugzilla/bugzilla/email_in.pl --default component=UI --default op_sys=All --default product=MyProduct --default rep_platform=All --default version=1.0 -vvvvvvvvv >> /home/bugzilla/email-import.log 2>&1\"" > ~/.forward
    chmod 710 .fetchmailrc
ProSupport for Business
