LaszloFolgerts
Aug 15, 2015Aspirant
SABnzbd for RN102
Hi, I've been using SABnzbd on my RN102 for some time now, without much problems to speak of. Recently, I had a pretty big download queue, which it wouldn't finish; it stopped at around 80%. ...
- Aug 16, 2015
Ok, I got it solved!
I'm not sure if it was part of the problem, but I was also having some problems copying some files to my NAS. I deleted a bunch of files but the NAS didn't show any extra space after that. After some looking around I found someone else had a similar problem and it had to do with the snapshots. I deleted all the snapshots of my movies and music shares, because those are where I made the most changes to in the past few weeks (lots of copying and deleting) and it freed up a couple hundred gigs. :)
After that, i thought "what the heck", what if I try installing python again? It installed successfully. I thought well, if that works, how will SABnzbd do? So I installed the .deb file I downloaded from here: http://apps.readynas.com/pages/?page_id=9 and it installed successfully, with all its settings unchanged. :)
very happy! :) :)
BrianL2
Aug 15, 2015NETGEAR Employee Retired
Hi LaszloFolgerts,
Try to install the SABnzbd app (ARM) that can be downloaded here.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
LaszloFolgerts
Aug 16, 2015Aspirant
Hey, thanks for the reply! :) I already tried that but it failed to install.
I also tried re-installing python, but after having it removed I couldn't get it installed again.
I tried rolling back a few firmware versions; as far back as to 6.2.2. When I tried to install python, It said it installed successfully, but it wouldn't show up on the "installed apps" list. I'm now back at firmware 6.2.5 again and now it just says that it failed to install.
I still can't get SABnzbd fully removed either. It still show up in the "installed apps" list, but without the icon (shows a broken image link.) Every time I try to remove it, I get the "removing application, this may take a few minutes" popup and that just stays up indefinitely. After I've refreshed the page the app is still there, nothing changed. When I try to switch SABnzbd on, I get the "toggling service" popup and then disappears again, but SABnzbd stays turned off.
Hoping someone knows what to do :)
- LaszloFolgertsAug 16, 2015Aspirant
very happy! :) :)
OK I solved the problem and selected it as a solution. But I made a few edits to remove a few typos and now its "awaiting moderation" or something...
- WhoCares_Aug 16, 2015Mentor
This may have been a problem with SABnzbd and log files. Since your solution isn't showing I have no idea what you did to solve the problem but would be interested in learning the details. So if you could drop me a message, that would be really great.
-Stefan
- LaszloFolgertsAug 17, 2015Aspirant
OK, this is weird. I tried to post the solution again, it showed up as being posted in the thread and now it's gone again. Also, when I edit a reply, the reply gets removed altogether.
What is it with this new forum?
