bseos
Jul 02, 2013Aspirant
Sabnzbd, Sickbeard, Python for OS6?
Just bought the Readynas 314 and was looking to get Sabnzbd and Sickbeard installed. Are these addons available anywhere yet? EDIT: I was itching pretty bad for Sabnzbd and Sickbeard, and i j...
bseos
super-poussin wrote: Did you take a look on Genie Market or in the available apps under Apps menus (must be using 6.0.8)
you can also find some addons in my community dropbox
You can find all my addons in a drop box : https://www.dropbox.com/sh/ie9pwk1wut72ias/p6_X2QeOIC
If you don not have dropbox installed use this link to install it, so I will have more space to share addons : http://db.tt/v4mPZg7l
Genie Market Does not have Sabnzbd or Sickbeard
I already checked out your addons, the only thing you have is Python.
Has anyone successfully gotton Sabnzbd or Sickbeard installed on OS 6?
I cant believe no ones mentioned this or provided a solution..
