JanHussaarts2
Jul 30, 2017Luminary
Shell In a Box failed to start / cannot be removed
Hi, I have the Poussin app Shell in a box installed. Recently it misses its logo on the installed app page. When I switch the app on a pop-up occurs: The app failed to start. Please update o...
- Aug 13, 2017
Due to lots of problems after trying to install git I had to do a factory reset.
After that Shell in a box was working again.
And it kept on working even after installing Lets Encrypt certificates and the other stuff I was running.
So probably it was broke because I did some other changes previously.
JanHussaarts2
Jul 31, 2017Luminary
Hello Marty M.
How can I contact poussin?
What is the name of the package I have to remove using apt-get?
Jul 31, 2017Guru - Experienced User
Unfortunately we haven't heard from super_poussin@ in a few months. If you click on the @ username you'll see a way to send him a private message (PM).
- JanHussaarts2Aug 13, 2017Luminary
