lobbie1978
Oct 05, 2016Tutor
Sickrage not working after re-install ReadyNAS 102
Hi guys, I've had the Sickrage app installed from WhoCares_ but I was having trouble updating it to the latest git. So I decided to remove it and install the version from Mhynlo After installati...
- Oct 07, 2016
Hello lobbie1978,
Logs shows package you installed broke some things. I suggest you contact support to get an L3 expert remote in and fix it. Note that you may need to purchase a per-incident contract as the support warranty of your NAS already expired.
JennC
Oct 05, 2016NETGEAR Employee Retired
Hello lobbie1978,
What's the firmware version of the NAS?
- lobbie1978Oct 06, 2016Tutor
Hi Jenn,
It's the latest. v6.5.2
Btw, I just got a new firmware this morning. v6.6.0. I installed it, but that doesn't change anything. Sickrage is still not working.
- JennCOct 06, 2016NETGEAR Employee Retired
Hello lobbie1978,
I do hope you did have time to read the released notes of 6.6.0, specially the info about the incompatibility of some apps.
By the way, you mentioned you installed the one from Mhynlo, where did you get it? Is it from the available apps list on the admin page?
