lobbie1978
Oct 05, 2016Tutor
Sickrage not working after re-install ReadyNAS 102
Hi guys, I've had the Sickrage app installed from WhoCares_ but I was having trouble updating it to the latest git. So I decided to remove it and install the version from Mhynlo After installati...
- Oct 07, 2016
Hello lobbie1978,
Logs shows package you installed broke some things. I suggest you contact support to get an L3 expert remote in and fix it. Note that you may need to purchase a per-incident contract as the support warranty of your NAS already expired.
lobbie1978
Oct 07, 2016Tutor
Thanks for the link. Bookmarked it. Might be useful in the future.
I hope you can figure the log out. I have no idea what to make of it...
JennC
Oct 07, 2016NETGEAR Employee Retired
Hello lobbie1978,
