testing123456's avatar
Oct 16, 2018
SickRage taken over update no longer works, use SickChill
Not sure who noticed that after an update Sickrage stopped working, if you then try to download a new version you land on the sickrage.ca page. If you install that version and want to access the GUI you are redirected to that site where you have to create a login.
This page is maintained by a different person echelon, who initially added cryptocurrencyminig to both his site and to the SickRage code. This is part of a long running dispute between echelon and the people who maintaned the code the last couple of years.
This group has now forked SickRage and created SickChill, less rage more chill!
Myhnlo created an updated installer linking to the SickChill git repo:
https://github.com/Mhynlo/readynas-sickchill/releases/tag/201810.15-ml0
Dave
    • longsifu's avatar
      longsifu
      Can someone help me(noob) how to do this change properly on my ReadyNAS 204?  This is what I've tried to do.
      1. Stop SickRage from the ReadyNAS app page.
      2. ssh to my readynas
      3. edit /apps/sickrage/app-config/config.ini
        1. Replace "git_remote_url = https://github.com/SickRage/SickRage.git" with "git_remote_url = https://github.com/SickChill/SickChill.git"
        2. Save config.ini
      4. Restart SickRage from ReadyNAS app page.
      checking the status gives me this:
      admin@readynas:/apps/sickrage/app-config$ systemctl status fvapp-sickrage
      ● fvapp-sickrage.service - Service for sickrage app
         Loaded: loaded (/lib/systemd/system/fvapp-sickrage.service; enabled; vendor p
      reset: enabled)
         Active: active (running) since Fri 2018-11-09 22:58:41 CST; 1s ago
      Main PID: 21649 (python)
         CGroup: /system.slice/fvapp-sickrage.service
                 └─21649 /usr/bin/python /apps/sickrage/SickBeard.py --nolaunch --data
      dir=/apps/sickrage/app-config --config=/apps/sickrage/app-config/config.ini --po
      rt=6765
      But I still can't connect to sickrage.  Connection refused.  Was there something else I was suppose to do?
      Thanks
      Nathan
ProSupport for Business
