Retired_Member's avatar
Retired_Member
May 18, 2019
SMB plus not running on RN104 under OS 6.10.0 Hotfix2
While not having any issues with my RN426 (OS6.9.5 HF1 Long-term Support) and RN204 (OS6.10.0 HF2), good ol' RN104 (OS6.10.0 HF2) is refusing to run SMB plus, though it claims that the app was successfully installed. Invoking it after installation renders an emtpy browser tab.
Here is what the log says prior to "successful" installation and after "successful" de-installation:
Any ideas? Not urgent, this is my guineapig nas. I'm not expecting a lot from it anymore as it has very well earned its bread of charity over the last few years and it would break my heart to throw it away. Its great for testing so I would like to keep it as long as possible.
Thanks in advance and kind regards
  • Retired_Member's avatar
    Retired_Member
    May 29, 2019
    OOM-9,many thanks for posting the smbplus configfile, which I compared with the one I have and found nothing wrong.
    However, I recalled, that I de-installed linux-dash a while ago. I now have it re-installed successfully again.
    That fixed the smbplus issue somehow. So I assume, that smbplus was totally fine, but one or more of the system's components used by linux-dash and smbplus were crippled/mis-configured by the un-install of linux-dash in the past.
  • I am having similar problem.
    RN104 6.10.0
    SMB Plus not installing
    Transmision not installing
    Log:
    System: Cannot install application Transmission for Readynas.
    System: Cannot install application SMB Plus.
    I get logged out  after it fails to install.
    • OOM-9's avatar
      OOM-9
      NETGEAR Expert
      I am interested on what is happening in these cases. I suspect there might be something related to the apt/deb installation that has encountered an issue from some package.
      Can you enabled Secure Diagnostics Mode and PM me the 5 digit number?
        Retired_Member
        Thanks for caring, dear OOM-9, but that is no option for me. Any hint from your side (further assumptions and suggestions) in a post from you are most welcome. Kind regards
        petercae?
ProSupport for Business
