MoonSire
Oct 22, 2013Aspirant
SMB Plus
I just noticed the new "SMB Plus" package in the "Available apps" section on my RN312. It sounds very interesting, very nice work bringing extra options to the people! :) I am just having problems ...
Grenouille25
Aug 15, 2015Aspirant
How can I get better performances?
Aug 15, 2015Guru - Experienced User
I think your post crossed mine. Look at my previous post, I added in a troubleshooting procedure after you read it.
- Grenouille25Aug 15, 2015Aspirant
Probably ^^
Ok I will check that, thanks a lot :)
- Grenouille25Aug 17, 2015Aspirant
Well, I re-ran the test and it was a little bit better (but not great):
Running a 400MB file write on I: 5 times...
Iteration 1: 1,16 MB/sec
Iteration 2: 1,18 MB/sec
Iteration 3: 1,16 MB/sec
Iteration 4: 1,37 MB/sec
Iteration 5: 1,35 MB/sec
Average (W): 1,25 MB/sec
Running a 400MB file read on I: 5 times...
Iteration 1: 2,33 MB/sec
Iteration 2: 2,41 MB/secI will try what you suggested (I may not have the time this week and I will be away next week) and I will keep you updated.
Thanks again very much for your help :)
