chirpa
Jul 13, 2009Luminary
Sparc platform development envrionment using Qemu
You can now run a fully emulated Sparc platform development environment on any system capable of running Qemu.
Download: readynas_compile_environment.qcow.gz
Default root password for this package is 'a'. The compile environment is all there for most common stuff.
# wget -q http://www.readynas.com/download/development/readynas_compile_environment.qcow.gz
# gunzip readynas_compile_environment.qcow.gz
# qemu-system-sparc -hda readynas_compile_environment.qcow -nographic
# qemu-system-sparc -hda readynas_compile_environment.qcow -nographic(I'm actually running this directly on a ReadyNAS Pro)
(qemu)
Nvram id QEMU_BIOS, version 1, machine id 0x80
CPUs: 1
invalid nvram partition length
nvram error detected, zapping pram
Welcome to OpenBIOS v1.0RC1 built on May 31 2007 23:50
Type 'help' for detailed information
[sparc] Booting file 'disk' with parameters ''
Not a bootable ELF image
Not a Linux kernel image
Loading a.out image...
Loaded 7680 bytes
entry point is 0x4000
Jumping to entry point...
SILO Version 1.4.13
boot:
Uncompressing image...
Loaded kernel version 2.6.18
Loading initial ramdisk (3210249 bytes at 0x3000000 phys, 0x60000000 virt)...
PROMLIB: obio_ranges 1
Booting Linux...
PROMLIB: Sun Boot Prom Version 3 Revision 2
Linux version 2.6.18-6-sparc32 (Debian 2.6.18.dfsg.1-23etch1) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 Fri Dec 12 16:29:52 UTC 2008
ARCH: SUN4M
TYPE: SPARCstation 5
Ethernet address: 52:54:0:12:34:56
Boot time fixup v1.6. 4/Mar/98 Jakub Jelinek (jj@ultra.linux.cz). Patching kernel for srmmu[Fujitsu TurboSparc]/iommu
PROM: Built device tree with 21266 bytes of memory.
Power off control detected.
Built 1 zonelists. Total pages: 31179
Kernel command line: root=/dev/sda2 ro
PID hash table entries: 512 (order: 9, 2048 bytes)
start_kernel(): bug: interrupts were enabled early
Console: colour dummy device 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 121200k/130232k available (1640k kernel code, 8880k reserved, 404k data, 136k init, 0k highmem)
Mount-cache hash table entries: 512
checking if image is initramfs... it is
Freeing initrd memory: 3135k freed
NET: Registered protocol family 16
IOMMU: impl 0 vers 4 table 0xf3200000[262144 B] map [65536 b]
sbus0: Clock 21.1250 MHz
dma0: Revision 2
dma1: Revision 2
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 4096 bind 2048)
TCP reno registered
ioremap: done with statics, switching to malloc
apc: power management initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Console: switching to colour frame buffer device 128x48
/iommu@0,10000000/sbus@0,10001000/SUNW,tcx@3,800000: TCX at 0:50800000, 24-bit depth
ffd54490: ttyS0 at MMIO 0x71100000 (irq = 44) is a zs
Console: ttyS0 (SunZilog zs0)
ffd54490: ttyS1 at MMIO 0x71100004 (irq = 44) is a zs
ffd5466c: Keyboard at MMIO 71000000 (irq = 44) is a zs
ffd5466c: Mouse at MMIO 71000004 (irq = 44) is a zs
Floppy drive(s): fd0 is 1.44M
FDC 0 is a S82078B
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
rtc_sun_init: Registered Mostek RTC driver.
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
Freeing unused kernel memory: 136k freed
input: Sun Type 5 keyboard as /class/input/input0
Loading, please wait...
Begin: Loading essential drivers... ...
SCSI subsystem initialized
esp0: IRQ 36 SCSI ID 7 Clk 40MHz CCYC=25000 CCF=8 TOut 167 NCR53C90(esp100)
scsi0 : Sparc ESP100 (NCR53C90)
Vendor: QEMU Model: QEMU HARDDISK Rev: 0.8.
Type: Direct-Access ANSI SCSI revision: 03
Vendor: QEMU Model: QEMU CD-ROM Rev: 0.8.
Type: CD-ROM ANSI SCSI revision: 03
Done.
Begin: Running /scripts/init-premount ...
SCSI device sda: 20971521 512-byte hdwr sectors (10737 MB)
sda: Write Protect is off
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3 sda4
sd 0:0:0:0: Attached scsi disk sda
Done.
Begin: Mounting root file system... ...
Begin: Running /scripts/local-top ...
Done.
Begin: Running /scripts/local-premount ...
Done.
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Begin: Running /scripts/local-bottom ...
Done.
Done.
Begin: Running /scripts/init-bottom ...
Done.
INIT: version 2.84 booting
INIT: Entering runlevel: 3
EXT3 FS on sda2, internal journal
sunlance.c:v2.02 8/24/03 Miguel de Icaza (miguel@nuclecu.unam.mx)
SunLance: using auto-carrier-detection.
eth0: LANCE 52:54:00:12:34:56
Starting LVM...done.
Checking filesystems...done
Setting kernel variables.
Mounting filesystems:
nothing was mounted
Initializing urandom... done.
Starting portmap...done.
Starting log daemons: syslogd klogd.
Starting atd...done
Starting inetd...done
Starting cupsd...done
Starting cron...done
debian-sparc login: root
Password:
Linux debian-sparc 2.6.18-6-sparc32 #1 Fri Dec 12 16:29:52 UTC 2008 sparc GNU/Linux
debian-sparc:~#
- msetnarbaAspirantis there in project the same for x86 ?
- airwoflAspirantDon't worry - got it working on Windows in the end. Needed the openbios-sparc32 compiled for Windows.
You can get it from the QEMU website under the Windows download page - look for the SPARC binary. - chirpaLuminaryOnly tested in Linux so far, we haven't tried Windows Qemu.
Scott, try this openbios-sparc32 build instead of the package: http://qemu-forum.ipi.fi/viewtopic.php?p=11539#p11539 - airwoflAspirantLike the idea!
I have tried booting this within QEMU (v0.90) on Windows (XP) and a couple of things cropped up:
* with --nographic, it complains it can't open monitor device 'stdio' and doesn't start.
* without --nographic, it states that Hard Disk 0 is not a bootable disk.
Here's the command line (-L . required to point it to the bios file):
qemu.exe -hda readynas_compile_environment.qcow -L .
Any thoughts? Basically am in Windows at the moment can't reboot this second into Ubuntu to test it there. - I fixed that error now, I had to install the openbios package. But now that I have it installed here is what happens:
Nvram id QEMU_BIOS, version 3, machine id 0x80
CPUs: 1 x FMI,MB86904
Welcome to OpenBIOS v1.0RC1 built on jan 24 2008 01:56
Loaded 7680 bytes
SILO Version 1.4.13
boot:
Booting Linux...
ARCH: SUN4M
PROM: Built device tree with 21328 bytes of memory.
IOMMU: impl 0 vers 5 table 0xf3200000[262144 B] map [65536 b]
dma0: Revision 2
dma1: Revision 0
TCP reno registered
/iommu@0,10000000/sbus@0,10001000/SUNW,tcx@3,800000: TCX at 0:50800000, 8-bit only
ffd54454: ttyS0 at MMIO 0x71100000 (irq = 44) is a zs
ffd54454: ttyS1 at MMIO 0x71100004 (irq = 44) is a zs
ffd54630: Keyboard at MMIO 71000000 (irq = 44) is a zs
ffd54630: Mouse at MMIO 71000004 (irq = 44) is a zs
Unable to handle kernel paging request at virtual address 7a000000
tsk->{mm,active_mm}->context = ffffffff
tsk->{mm,active_mm}->pgd = fc000000
\|/ ____ \|/
/_| \__/ |_\
\__U_/
swapper(0): Oops [#1]
PSR: 044010c5 PC: f001c770 NPC: f001c774 Y: 00000000 Not tainted
PC: <apc_swift_idle+0x8/0x1c>
%G: 00000010 f022a000 fd013000 f05b0000 04101fe5 00000040 f000e000 00000001
%O: 00000019 00000032 00000010 00000008 f00d941c 00000001 f000fec8 f0014a40
RPC: <cpu_idle+0xc0/0xfc>
%L: 00000190 f7f2d580 f01d49d0 f01d4aac f022373c 00000066 00000009 00000000
%I: f01d57c0 00000000 00000010 00000008 f00d941c f0235000 f000ff30 f0205f64
Caller[f0205f64]: _etext+0x68754/0x697e8
Caller[f0205790]: _etext+0x67f80/0x697e8
Caller[ffd07fec]: 0xffd07ff4
Instruction DUMP: 90102000 81c3e008 90102000 <033c08a8> c4006220 c2088000 82106001 c2288000 81c3e008
Kernel panic - not syncing: Attempted to kill the idle task!
<0>Press Stop-A (L1-A) to return to the boot prom
no cont in shutdown!
Any ideas?
Thanks again,
SK - I am trying to use this on Ubuntu so I can compile the full_audit.so for samba but every time I try to start I get the error:
/usr/share/qemu/openbios-sparc32: No such file or directory
qemu: could not load prom '/usr/share/qemu/openbios-sparc32'
I have looked everywhere trying to find a resolution and I can't find anything. I did look within the /usr/share/qemu and it has symlinks to a folder called openbios from all of the files begining with openbios- (like openbios-sparc32) but the actual folders they are linking to do not exist. I have done an update and reinstall of qemu but it is the same, I also removed and installed from a debian package, still the same thing.
Thanks in advance,
SK
