xiaorrulez
Jul 04, 2012Aspirant
Startup scripts, where to put them?
Hi guys, just got my new Ultra 6 Plus a few days back. Installed many cool things and slowly migrating data from 5 loose drives onto the NAS. Loving every second! *I don't do Linux much. Just inst...
sbb_ausr
Dec 07, 2012Aspirant
Hi there!
First of all, I do not know if this is right board of forums here for my questions, so if it is must not be here - please move it in right place. Thank you in advance!
I faced a problem in my tries to setup one script to be executed at every boot.
Let me explain: I am working at one factory, where the DB backup is ~30GB. We are using two devices - NV+ and Duo. It is done every day at 2~3.00 AM and ReadyNas Duo is set to copy backup file after 3.00 AM once a day, which is done approximately around 5~6.00 AM (our network is 100 Mb and is disabled aggresive mode with MTU 1492). Disc capacity of Duo is ~450GB, so after 12-13 copied backups, I am receiving email for disk usage warning. If I didn't take action, after 14-th file there is not possibility to save data, and files are broken. My target is to save last 7 backups - there is no option for this in FrontView - if I am wrong, please, correct me. So my solution was to create script, which make this, what I want and I am starting it via SSH every time, when I received a disk warning email.
Last three days I have tried to install the file as a service (without breaking loop) - in /etc/init.d and after that to execute update-rc.d command:
dUADB file:
In both of tries, the system have failed (after restart, only power button was blinking) and was necessary to being reinstalled OS or factory default-ed the device. :)
Is there something wrong in my steps, in my script?
Best Regards
GR
update-rc.d /etc/init.d/dUADB start 90 2 3 4 5 . stop 90 0 1 6 .
dUADB file:
#!/bin/bash
declare i daysSave=7;
declare i cnt=0;
for ((;;))
do
for file in `ls -t /c/AtlasDB_bkp/*`;
do
if [ $cnt -lt $daysSave ];
then
echo $file;
else
rm $file;
fi
let '++cnt';
done
break;
sleep 3600;
done
Best Regards
GR
