bonnier243's avatar
bonnier243
Follower
Dec 06, 2015
WNDA4100 error on startup
Running Vista Home on Dell PC.  Using Netgear N900 WiFi Dual Band USB adapter.  Getting following error in startup:
'WNDA4100 Genie MFC Application has stopped working.  A problem caused the program to stop working correctly.  Windows will close the program and notify you if a solution is available."
I am connected to the router.  Not sure what the error means, and would like to fix whatever is wrong.  Any help would be appreciated.  Thanks.
  • Hi bonnier243,
    Please uninstall the genie utility of WNDA4100 and check if it has the same error.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi bonnier243,
    • Doughboy72's avatar
      Doughboy72
      How does one uninstall the Genie function but still maintain the ability to use the USB Wireless Connection.  It seems I have only been able to uninstall the entire software suite thus far
      • JamesGL's avatar
        JamesGL
        The genie is just a software you can use to connect to the network. If no genie, you can still use the windows utility to connect.
