MoonSire
Feb 08, 2014Aspirant
subversion configuration
I am trying to get a subversion server running on my RN314. I have the following packages installed: root@sausage:/root# dpkg --get-selections | grep subversion subversion install subversion-n...
twinpeaks1
Mar 01, 2015Aspirant
I can only speak for my RN102. The above steps were all I did to set up SVN. I can't remember under which firmware version I did the install, but it was the current version back then. I keep the FW always up-to-date, so now I have 6.2.2 and SVN is still running OK.
Are you sure that you don't have the /etc folder? What's the output of this command?
What firmware are you running?
ls /
