MoonSire
Feb 08, 2014Aspirant
subversion configuration
I am trying to get a subversion server running on my RN314. I have the following packages installed: root@sausage:/root# dpkg --get-selections | grep subversion subversion install subversion-n...
twinpeaks1
Mar 10, 2015Aspirant
Good to hear that you got a step further. These system files aren't shared via SMB, so you need direct access to edit them as you did with vi.
On Windows WinSCP is a great tool for such things that makes browsing the file system and editing files very easy, but as the name suggest, it's only for Windows.
Don't know if there are similar tools for Mac.
OK, regarding your error message. It's a bit vague, don't know what "invalid argument" means. Maybe double check that your svnserve.service file contais the above contents. Or maybe check the permissions:
root@readynas:~# ls -l /etc/systemd/system/svnserve.service
-rw-r--r-- 1 root root 224 Feb 14 2014 /etc/systemd/system/svnserve.service
