MoonSire
Feb 08, 2014Aspirant
subversion configuration
I am trying to get a subversion server running on my RN314. I have the following packages installed: root@sausage:/root# dpkg --get-selections | grep subversion subversion install subversion-n...
Hairy1
Apr 05, 2015Aspirant
Hi quickly_now, thank you for your step by step guide!
Unfortunately I can't open the URL in step 6. The restart of the web server worked (once I fixed the SUBVERSION.conf script due to a copy paste error on my part).
I cannot see anything obvious wrong, I went through all the steps and they appeared to succeed, but the URL (using my nas server name) never returns and so I don't get asked for a username and password (which I generated with one of the various htpasswd generator websites).
Any pointers at what I should check?
EDIT: also I realised the path you suggested for SUBVERSION.conf was incorrect, it should be:
Cheers
John
- /etc/apache2/conf.d
Cheers
John
