highintensity
May 14, 2012Tutor
Support for Foscam FI8918W IP Camera
I have a few of theses and would like to add them. The Panasonics work very well so far. B
tiranor
Aug 27, 2013Aspirant
rob230 wrote: Is this product dead now? Would be nice if we could just add simple stream urls like IPADDRESS/videostream.cgi?user=admin&pwd=psd that we know work :?
As i have 2 Foscam ip cams, i don't want to spend so much money for something i'm not sure is supported.
ATM, i directly record the videostream on my NAS, via the curl function, and a cron job. The only downside is that it records everything, and not just when there is a movement.
Maybe i'll try later to create another cron job to erase all videos not linked to any snapshot done directly by the camera software.
- bizmateMay 14, 2017Tutor
Could you share your curl script, maybe on github or something public, and how do you detect the stream address? I have a very cheap chinese PAN camera. I want to buy a better HD IP cam but I am always interested in alternative approaches to integrate directly as you are doing at the moment
