ASC
Sep 26, 2016Aspirant
Surveillance Add On for RND4000-100 Ready NAS NV+ 4.1.14
Is there a camera add on for this model? I would like to add an IP camera. Readyy NAS NV+ RND 4000-100. Radiator 4.1.14. Also is there any way I can upgrade this "old" model.
ASC
Thank you for your answer. I need to add a couple of cameras and was curious if a third party solution had been developed and/or if it is at all possible to upgrade my NAS (hardware) to a NAS that will accept surveillance add-on. This is for home use.
I have NV+ and an NV; both are working fine and have been for the last 4/5 years. I only changed the power supply on one - ironically the newer one - because it smoked out. Luckily I was able to buy one online and with just some minor mods was able to fit it in. I know that these are NOT supported but I hate to trash them for something newer. If / when I do I will probably move away from this brand.
Any help will be appreciated.
JennC
Sep 27, 2016NETGEAR Employee Retired
Hello ASC,
These ReadyNAS NV+ and NV you are old and have joined EOL year ago and are one of the most basic models. I apologize but the ReadyNAS Surveillance has some requirements that these old models do not meet. Please see ReadyNAS Surveillance info.
I hope you understand and decide to upgrade your NAS unit after backing up important files.
- Nov 24, 2016Retired_Member
