Blueray3
Jun 14, 2017Guide
Syncing Dropbox
RN312
When I sync from the Dropbox root directory, I see the message in the app: syncing the root folder will sync the entire public cloud, preventing you from adding new sessions.
Am not sure what this means. Does "public cloud" mean that syncing changes permissions on either the Dropbox or the ReadyNAS? And what is "adding new sessions"? -Does this mean that I can not add new folders to either the Dropbox or to the ReadyNAS Dropbox share (assuming bidirectional syncing) or does it mean something else? -Thanks
1 Reply
- JennCNETGEAR Employee Retired
Hello Blueray3,
I believe this is something you should ask DropBox as although this is from the admin page of the NAS, this is a setting of the DropBox app that has been incorporated with the NAS, the settings and updates should still be answered by DropBox.
