cat509
Feb 05, 2014Tutor
tiny tiny rss problem
I have just installed tiny tiny rss on my Nas312. When I go to the install page that comes up after hitting the Launch button from the Apps section of the admin console I put in the login name etc. th...
aVe2000
Nov 09, 2014Aspirant
Hello Super-Poussin,
thank you for your reply. i did try the new version with the same result.
Checking configuration
Configuration check succeeded.
Checking database
Unable to connect to database using specified parameters.
Maybe some of the parameters are wrong? Does it interfer with other installations?
If you need a hand with debugging i will try to assist here. I have some basic linux knowledge.
Regards
Checking database
Regards
