cat50998's avatar
cat50998
Follower
Apr 23, 2018
Replacement for Tiny Tiny RSS or Selfoss
I have a Readynas 312 running os 6.9.3. I had Selfoss and at one point Tiny Tiny Rss installed on my nas. They haven't been updated in years. Anyone have a recommendation for a replacement?
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi cat50998
    Welcome to the Community!
    Are you getting issues with the current firmware? I would suggest using the same RSS feed reader if you are not getting any issues with it. Contacting the developer is also an option to check if there are any updates available for the App.
    Other Community members might be able to share the App they use.
    Regards
  • Marc_V's avatar
    Marc_V
    Hi cat50998
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
