cat50998
Apr 23, 2018Follower
Replacement for Tiny Tiny RSS or Selfoss
I have a Readynas 312 running os 6.9.3. I had Selfoss and at one point Tiny Tiny Rss installed on my nas. They haven't been updated in years. Anyone have a recommendation for a replacement?
Marc_V
May 22, 2018NETGEAR Employee Retired
Hi cat50998
Welcome to the Community!
Are you getting issues with the current firmware? I would suggest using the same RSS feed reader if you are not getting any issues with it. Contacting the developer is also an option to check if there are any updates available for the App.
Other Community members might be able to share the App they use.
Regards
