ssurba's avatar
ssurba
Guide
Dec 03, 2015
Transmission 2.84 for ReadyNAS OS 6
Hi all,
you may download the latest versions of Transmission Bittorrent client for NETGEAR ReadyNAS storage systems from my GitHub:
The latest maintained version for ReadyNAS OS 6 is 2.84-0.01.
Comments, suggestions and bug reports (if any) are always welcome. :-)
Happy ReadyNASing!
Best regards, Sergey.
    • DaneA's avatar
      DaneA
      NETGEAR Employee Retired
      Hi siddadav,
      Welcome to the community! :)
      The latest version of the Transmission app for the ReadyNAS OS 6 is v3.00.8.  You may double-check it here.
      Here are the steps in installing app/s below:
      a. On the web-GUI of your NAS, click on Apps tab.
      b. Click on Available Apps then search for Transmission.  You may click on the Refresh button located at the upper right corner of the Available Apps page to refresh the list of apps that are available.
      c. Once you locate the Transmission app, click on install.  Wait for a few moments.
      d. After a few moments, click on Installed Apps to double-check that the Transmission app has been installed.
      e. Click the Launch button to lauch the Transmission app.
      Hope it helps.
      DaneA
      NETGEAR Community Team
      • ssurba's avatar
        ssurba
        Guide
        Please note despite being labelled v3.00.8 this package installs Transmission 2.82.
ProSupport for Business
