gyves1
Jul 28, 2015Luminary
Transmission add-on for ReadyNAS
Hi, I have installed the Transmission add-on version 3.0.0.8 from DEV "Poussin" on my ReadyNAs 312 (fw 6.2.4) but often the web UI of this add-on falls, and can't available anymore on installed por...
mdgm-ntgr
Jul 28, 2015NETGEAR Employee Retired
Do you have any other apps installed?
Do you lose access to the web interface for other apps as well?
gyves1
Jul 29, 2015Luminary
Hi,
Thank you for your reply
I have followed your suggestion by installing an another App (Qbittorent), and it's the same problem.
I have typed the ip address (with same port 8181) of my NAS, and now I can find my Transmission WebUi;
The issue doesn't come from Transmission App but from DNS from my ReadyNAS network setting or from my Netgear router, I don't know
But when I use my ReadyNAS name with port80 in IE, I can find my ReadyNas main page, like this https://my_readynas_name/ but when I use an other port number (for app) https://my_readynas_name:8181 (example for Transmission add-on) it's not working :-(
