gyves1
Jul 28, 2015Luminary
Transmission add-on for ReadyNAS
Hi, I have installed the Transmission add-on version 3.0.0.8 from DEV "Poussin" on my ReadyNAs 312 (fw 6.2.4) but often the web UI of this add-on falls, and can't available anymore on installed por...
BrianL2
Jul 28, 2015NETGEAR Employee Retired
Hi gyves1,
Try to uninstall the add-on and get a fresh copy here and download the x86 type. Upload it in your NAS and wait a minute for it to be installed. Check your installed add-ons, turn on or toggle the transmission add-on then launch it. The username and password is admin.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
gyves1
Jul 29, 2015Luminary
Hi,
Thank you for your reply.
I have already reinstalled the add-on, I think it's a DNS problem from my ReadyNAS or from Netgear Router, see my reply below on mdmg message.
Best regards,
Yves
