Equinox1
Apr 14, 2016Guide
Transmission crashing after a couple of seconds
I've had the canonical Transmission plug-in installed on OS6 for months (the 3.0.8 that you install from the UI). Yesterday I noticed that there is a newer version on super_poussin dropbox, so I trie...
- Apr 14, 2016
yep now install the transmission interface package :) (also in my dropbox)
Equinox1
Apr 14, 2016Guide
With transmissionr6_3.00.8_all.deb it worked, and seems stable. Now, I'll try to get the old config back.
Thanks for the help!
What was the problem?
super_poussin
Apr 14, 2016Virtuoso
too much cpu optimization in compilation phase :P
- Equinox1Apr 14, 2016Guide
In this case, I can assure you it wasnt by lack of CPU power. The ReadyNAS in question is the Pro6 with a Core2Quad :-D
- StephenBApr 14, 2016Guru - Experienced User
He's not suggesting that - he's saying that turning off some optimization in the compiler "solved" the problem.
That means either the compiler has a bug, or that the program has a bug (perhaps timing dependent) that disappears when the optimizer is turned off.
