Deaf_Raiders1
Feb 28, 2016Aspirant
transmission duo 2.42 - working settings
Been trying all day to get this working, I keeps working for about 5mins then crashes with Connection Refused... get on my nerves now can't figure out what the issue is, Here is my settings.json (whi...
Deaf_Raiders1
Mar 02, 2016Aspirant
Nope still running this morning when I got up. Can't skip volume check I can't get into the browser or is there a method of button to press? I don't want to lose stuff on the NAS my final year of college work is on it but I only have some of the backup
Mar 02, 2016Guru - Experienced User
It's a boot option, not a web browser option. See page 16 of your hardware manual.
http://www.readynas.com/download/documentation/HM/Duov1_NV%2Bv1_HW_en_06Dec11.pdf wrote:
For example, to perform a skip volume check, press and hold the Power button until all Disk LEDs flash once, after 5 seconds.
You do want to be careful on the duo, since there is no LCD panel to prompt you. But this particular option isn't very difficult.
One option is to power down the NAS, and connect disk 1 to a PC. There's a freeware utility called linux reader that should be able to extract your data. http://www.diskinternals.com/linux-reader/ Don't format the disk for windows of course.
- Deaf_Raiders1Mar 02, 2016Aspirant
Thank you i need to buy an external hard drive to transfer the data too :)
- Deaf_Raiders1Mar 05, 2016Aspirant
Backuped finally done and NAS Duo as been restored factory setting, still get conenctions refused when trying access transmission.
