Deaf_Raiders1
Feb 28, 2016Aspirant
transmission duo 2.42 - working settings
Been trying all day to get this working, I keeps working for about 5mins then crashes with Connection Refused... get on my nerves now can't figure out what the issue is, Here is my settings.json (whi...
Mar 02, 2016Guru - Experienced User
Deaf_Raiders1 wrote:
Can't skip volume check I can't get into the browser or is there a method of button to press?
It's a boot option, not a web browser option. See page 16 of your hardware manual.
http://www.readynas.com/download/documentation/HM/Duov1_NV%2Bv1_HW_en_06Dec11.pdf wrote:
For example, to perform a skip volume check, press and hold the Power button until all Disk LEDs flash once, after 5 seconds.
You do want to be careful on the duo, since there is no LCD panel to prompt you. But this particular option isn't very difficult.
I don't want to lose stuff on the NAS my final year of college work is on it but I only have some of the backup
One option is to power down the NAS, and connect disk 1 to a PC. There's a freeware utility called linux reader that should be able to extract your data. http://www.diskinternals.com/linux-reader/ Don't format the disk for windows of course.
Deaf_Raiders1
Mar 02, 2016Aspirant
Thank you i need to buy an external hard drive to transfer the data too :)
