kjbnz
Aug 26, 2015Aspirant
Transmission failes to initialize
Hi there, I have a readynas 314 - when I load up transmission I get the following error. 404: Not Found Couldn't find Transmission's web interface files! Users: to tell Transmission where to lo...
JennC
Aug 26, 2015NETGEAR Employee Retired
Hi kjbnz,
Please try adding 8.8.8.8 as secondary DNS on the ReadyNAS admin UI (Network - Settings of NIC - DNS) and see if same problem.
Please also check if you get the same problem when using other web browser.
Let us know the model number of the NAS and the firmware version.
- kjbnzSep 03, 2015Aspirant
No - adding the IP to the DNS did not solve the problem.
Model Number: RN314
Firmware: 6.2.4
Thank you
