kjbnz
Aug 26, 2015Aspirant
Transmission failes to initialize
Hi there, I have a readynas 314 - when I load up transmission I get the following error. 404: Not Found Couldn't find Transmission's web interface files! Users: to tell Transmission where to lo...
JennC
Aug 26, 2015NETGEAR Employee Retired
Hi kjbnz,
Please try adding 8.8.8.8 as secondary DNS on the ReadyNAS admin UI (Network - Settings of NIC - DNS) and see if same problem.
Please also check if you get the same problem when using other web browser.
Let us know the model number of the NAS and the firmware version.
kjbnz
Sep 03, 2015Aspirant
No - adding the IP to the DNS did not solve the problem.
Model Number: RN314
Firmware: 6.2.4
Thank you
- JennCSep 03, 2015NETGEAR Employee Retired
Hi kjbnz,
Do you get the same problem on otehr web browsers?
Also, please check if you will be able to launch other apps.
- kjbnzSep 03, 2015Aspirant
Yes - The same issue in Chrome/Safari/Firefox
Thank you
- JennCSep 04, 2015NETGEAR Employee Retired
Hi kjbnz,
How about removing then re-adding the add-on again?
If same problem, you may need to contact support center
I've checked your records and found that you have registered a ReadyNAS 314 with the email address you used here. Are you from Exeed Limited? Please use your exeed email address that has the PowerShift profile when you contact support.
