Rembo's avatar
Rembo
Transmission torrent not starting since RAIDiator 4.2.28
SInce I've upgraded my ReadyNAS Ultra 4 Plus to RAIDiator 4.2.28 last weekend the torrents are not starting anymore.
I have tried to reinstall Transmission 2.82 and to downgrade to RAIDiator 4.2.27 without result.
The torrents are stuck with the following status:
Tier 1
    • udp://tracker.publicbt.com:80
    • Announce error: Connection failed - Today 07:45:31 PM
      Next announce in 57 minutes
      Scrape error: Connection failed - Today 08:30:22 PM
  • Seeders:
  • N/A
  • Leechers:
  • N/A
  • Downloads:
  • N/A
Tier 2
      • udp://open.demonii.com:1337
      • Announce error: Connection failed - Today 08:30:57 PM
        Next announce in 1 hour, 43 minutes
        Scrape error: Connection failed - Today 07:50:21 PM
  • Seeders:
  • N/A
  • Leechers:
  • N/A
  • Downloads:
  • N/A
It's not a problem with my router, firewall or ISP because Transmission has no problem with the same torrents on my Mac which is on the same subnet.
Any suggestion ?
  • StephenB's avatar
    Is the NAS using dhcp or a static address?
    If dhcp- were you forwarding ports for transmission in the router?  If so, did the local address change?
    if static - you might want to check that your subnet and dns settings are still correct.
    • Rembo's avatar
      Rembo
      I'm using static DHCP and my DNS are looking like that with IPv6 first:
      RNU4P:~# cat /etc/resolv.conf
      nameserver 2001:4860:4860::8888
      nameserver 2001:4860:4860::8844
      nameserver 192.168.1.1
      nameserver 213.221.144.240
      nameserver 213.221.143.240
      RNU4P:~#
      As on my Mac it's IPv4 first:
      • StephenB's avatar
        Does anything change if you disable IPv6 on the NAS?
ProSupport for Business
