gerk
Aug 31, 2015Aspirant
Trying to get SDK complete: apt-get update fails with 403 forbidden
When trying to install the readynas SDK into a chroot environment on Ubuntu 15.04, as described in http://apps.readynas.com/pages/?page_id=90 (with version for packages set to 6.2.3), the following ...
- Aug 31, 2015
Can you try using www.readynas.com instead and see if that works for you?
mdgm-ntgr
Aug 31, 2015NETGEAR Employee Retired
- gerkSep 01, 2015Aspirant
This at least gets installation of build-essential going. I'll keep you informed on total result.
Time to update the readme in SDK ?
Next ommision in the readme for SDK seems to be that in step 2.1 it is said to add an embedian repository, but the netgear related contents of sources.list in this section is identical to the (to be fixed) contents in section 1.2.
Where to find the emdebian repo ??
- siignaJan 21, 2016NETGEAR Employee Retired
The SDK readme is a bit out of date. The reference to "embedian" (really emdebian) is incorrect. The SDK is slated for an update in the near future.
The required cross compilation tools are included in the dev component of the ReadyNAS repository, which you would have added in Step 1.2 of the readme. You can then install the packages from Step 2.3 in your chroot.
