peos42
Mar 04, 2018Tutor
Forbidden VLANs
Hi all
Let´s assume I configure a a trunk port this way....
--snip--
interface 1/xg26
description 'SERVER3'
switchport mode trunk
switchport trunk native vlan 2026
switchport trunk allowed vlan 2-4,21,899,2026
exit
--snip--
and an access port this way...
--snip--
interface 1/g10
description 'VLAN 2 - XPY transmitter'
switchport mode access
switchport access vlan 2
exit
--snip--
Will that mean a command like this:
vlan participation exclude 999,1201
is meaningless and has no effect. The question is if
on the trunk port, and
aon the access port
automatically forbids all other VLANs.
Tnx
/Peo
I am satisfied by doing exclude. Therefor I do not want to spend more time with a private chat. Also... I think the community deserve to know. To get help in the forum is one thing. To share info is another. The second one is not fulfilled if going into a private chat.
As I have a work around with the exclude (that I think should not be needed), I am done in this thread. But I do think netgear should consider to clarify for all as it is a securrity matter.
Tnx for your time
/Peo
- peos42Tutor
Hi again.
Did some more checks. It at least seems like there is a potential security issuse by not using..
vlan participation exclude <vlannum>
At least for VLAN1 that seems to be allowed anyway..... Or do I interprete the output of the show command wrong?
(switch0.incedo.org) #show running-config interface 1/g3
!Current Configuration:
interface 1/g3
description 'TRUNK - Switch 2 level3'
switchport trunk native vlan 2003
switchport trunk allowed vlan 2-4,21,899,2003
exit(switch0.incedo.org) #show interfaces switchport 1/g3
Port: 1/g3
VLAN Membership Mode: Trunk
Access Mode VLAN: 1 (default)
General Mode PVID: 1 (default)
General Mode Ingress Filtering: Disabled
General Mode Acceptable Frame Type: Admit all
General Mode Dynamically Added VLANs:
General Mode Untagged VLANs: 1
General Mode Tagged VLANs:
General Mode Forbidden VLANs:
Trunking Mode Native VLAN: 2003
Trunking Mode Native VLAN tagging: Disable
Trunking Mode VLANs Enabled: 2-4,21,899,2003
Protected Port: False- peos42Tutor
Is this maybe the wrong part of the forum for such questions?
Tnx
Peo
- DaneANETGEAR Employee Retired
Hi peos42,
Welcome to the community! :)
I inquired your concern to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, when using the switchport trunk allowed vlan command, if the switch port receives traffic with a VLAN tag for a VLAN ID not in the allowed list, it will drop the packet.
As reference, kindly read page 416 of the CLI Command reference manual here.
The command vlan participation exclude is used so the interface (port) is never a member of a particular VLAN. This is equivalent to registration forbidden.
DaneANETGEAR Community Team
