DanskePiet
Jan 06, 2019Aspirant
GS728TPv2 Forbidden VLANs
Hi,
we using 8 of the GS728TPv2 switchws. All of them are allready configured but on 2 switches we have to define forbidden VLANs on some ports. How can I do this over the Web-GUI?
Piet
Hi DanskePiet,
Welcome to the community! :)
I inquired your concern to the higher tier of NETGEAR Support and got a feedback today. As per the higher tier of NETGEAR Support, the purpose of Forbidden VLANs is to prevent ports joining a VLAN when ports can be dynamically added using a protocol like GVRP. There is a Remove All option, where ports that were dynamically registered through GVRP are removed from the VLAN. Kindly check page 129 of the GS728TPv2 user manual here.
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi DanskePiet,
DaneA
- DanskePietAspirant
Hi Dane
Thanks for the replay to my question! This answer my question.
