DanskePiet
Jan 06, 2019Aspirant
GS728TPv2 Forbidden VLANs
Hi,
we using 8 of the GS728TPv2 switchws. All of them are allready configured but on 2 switches we have to define forbidden VLANs on some ports. How can I do this over the Web-GUI?
Regard...
- Jan 10, 2019
Hi DanskePiet,
Welcome to the community! :)
I inquired your concern to the higher tier of NETGEAR Support and got a feedback today. As per the higher tier of NETGEAR Support, the purpose of Forbidden VLANs is to prevent ports joining a VLAN when ports can be dynamically added using a protocol like GVRP. There is a Remove All option, where ports that were dynamically registered through GVRP are removed from the VLAN. Kindly check page 129 of the GS728TPv2 user manual here.
DaneA
NETGEAR Community Team
DaneA
Jan 10, 2019NETGEAR Employee Retired
Hi DanskePiet,
DaneA
DanskePiet
Jan 10, 2019Aspirant
Hi Dane
Thanks for the replay to my question! This answer my question.
