DanskePiet's avatar
DanskePiet
GS728TPv2 Forbidden VLANs
Hi,   we using 8 of the GS728TPv2 switchws. All of them are allready configured but on 2 switches we have to define forbidden VLANs on some ports. How can I do this over the Web-GUI?   Regard...
  • DaneA's avatar
    Jan 10, 2019
    Hi DanskePiet,
    Welcome to the community! :)
    I inquired your concern to the higher tier of NETGEAR Support and got a feedback today.  As per the higher tier of NETGEAR Support, the purpose of Forbidden VLANs is to prevent ports joining a VLAN when ports can be dynamically added using a protocol like GVRP.  There is a Remove All option, where ports that were dynamically registered through GVRP are removed from the VLAN.  Kindly check page 129 of the GS728TPv2 user manual here.
    DaneA
    NETGEAR Community Team
ProSupport for Business
