peos42
Mar 04, 2018Tutor
Forbidden VLANs
Hi all Let´s assume I configure a a trunk port this way.... --snip-- interface 1/xg26 description 'SERVER3' switchport mode trunk switchport trunk native vlan 2026 switchport trunk allowed ...
- Mar 29, 2018
I am satisfied by doing exclude. Therefor I do not want to spend more time with a private chat. Also... I think the community deserve to know. To get help in the forum is one thing. To share info is another. The second one is not fulfilled if going into a private chat.
As I have a work around with the exclude (that I think should not be needed), I am done in this thread. But I do think netgear should consider to clarify for all as it is a securrity matter.
Tnx for your time
/Peo
DaneA
Mar 27, 2018NETGEAR Employee Retired
I inquired again your concern to the higher tier of NETGEAR Support and just got a feedback. It was suggested that you open a chat or online support ticket with NETGEAR Support here at anytime in order to further investigate if this is a possible flaw as per you have described here in the forum thread.
DaneA
NETGEAR Community Team
peos42
Mar 29, 2018Tutor
Tnx for your time
/Peo
