peos42
Mar 04, 2018Tutor
Forbidden VLANs
Hi all Let´s assume I configure a a trunk port this way.... --snip-- interface 1/xg26 description 'SERVER3' switchport mode trunk switchport trunk native vlan 2026 switchport trunk allowed ...
- Mar 29, 2018
I am satisfied by doing exclude. Therefor I do not want to spend more time with a private chat. Also... I think the community deserve to know. To get help in the forum is one thing. To share info is another. The second one is not fulfilled if going into a private chat.
As I have a work around with the exclude (that I think should not be needed), I am done in this thread. But I do think netgear should consider to clarify for all as it is a securrity matter.
Tnx for your time
/Peo
peos42
Mar 04, 2018Tutor
Hi again.
Did some more checks. It at least seems like there is a potential security issuse by not using..
vlan participation exclude <vlannum>
At least for VLAN1 that seems to be allowed anyway..... Or do I interprete the output of the show command wrong?
(switch0.incedo.org) #show running-config interface 1/g3
!Current Configuration:
interface 1/g3
description 'TRUNK - Switch 2 level3'
switchport trunk native vlan 2003
switchport trunk allowed vlan 2-4,21,899,2003
exit
(switch0.incedo.org) #show interfaces switchport 1/g3
Port: 1/g3
VLAN Membership Mode: Trunk
Access Mode VLAN: 1 (default)
General Mode PVID: 1 (default)
General Mode Ingress Filtering: Disabled
General Mode Acceptable Frame Type: Admit all
General Mode Dynamically Added VLANs:
General Mode Untagged VLANs: 1
General Mode Tagged VLANs:
General Mode Forbidden VLANs:
Trunking Mode Native VLAN: 2003
Trunking Mode Native VLAN tagging: Disable
Trunking Mode VLANs Enabled: 2-4,21,899,2003
Protected Port: False
peos42
Mar 12, 2018Tutor
Is this maybe the wrong part of the forum for such questions?
Tnx
Peo
- DaneAMar 13, 2018NETGEAR Employee Retired
Hi peos42,
Welcome to the community! :)
I inquired your concern to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, when using the switchport trunk allowed vlan command, if the switch port receives traffic with a VLAN tag for a VLAN ID not in the allowed list, it will drop the packet.
As reference, kindly read page 416 of the CLI Command reference manual here.
The command vlan participation exclude is used so the interface (port) is never a member of a particular VLAN. This is equivalent to registration forbidden.
DaneANETGEAR Community Team
- peos42Mar 13, 2018Tutor
I had this on an interface...
(switch0.incedo.org) #show running-config interface 1/xg28
interface 1/xg28
description 'FIBER IN'
switchport trunk native vlan 999
switchport trunk allowed vlan 21,999
no lldp transmit
no lldp receive
no lldp transmit-tlv port-desc
no lldp transmit-tlv sys-name
no lldp transmit-tlv sys-desc
no lldp transmit-tlv sys-cap
no lldp transmit-mgmt
no lldp med
exit(switch0.incedo.org) #show interfaces switchport 1/xg28
Port: 1/xg28
Trunking Mode Native VLAN: 999
Trunking Mode VLANs Enabled: 21,999
Protected Port: FalseLooks fishy... So I added...
interface 1/xg28
vlan participation exclude 1
no lldp transmit
no lldp receive
no lldp med
exit
(switch0.incedo.org) (Interface 1/xg28)#show interfaces switchport 1/xg28Port: 1/xg28
General Mode Forbidden VLANs: 1
Protected Port: FalseBut you mean this os not neccessary?
/Peo
- DaneAMar 20, 2018NETGEAR Employee Retired
I inquired the configuration you have posted to the higher tier of NETGEAR Support and just received a feedback. According to the higher tier of NETGEAR Support, you should change the PVID on the port to match either the Native VLAN or else if you want the port in a specific VLAN, then run the show command again.
DaneA
