super_poussin's avatar
Apr 26, 2010
Twonky 6.0/6.0.1/6.0.23/6.0.30/6.0.31RC6/6.0.32/6.0.34
TwonkyMedia
  • Description:
    A server utility to help you manage the contents of your media folders
    It's based on Upnp and will work with for ex : PS3 , Windows Media ..
    Twonky is not Free, you will need to buy a license after the trial period.
  • Requirements: RAIDiator 4.1.6+
  • Platform: Sparc
  • Current Version: 6.0.32
    TwonkyMedia 6.0 (06/16/10)
    TwonkyMedia 6.0.1 (08/04/10)
    TwonkyMedia 6.0.23 (09/24/10)
    TwonkyMedia 6.0.30 (12/8/10)
    TwonkyMedia 6.0.31RC6 (02/13/10)
    TwonkyMedia 6.0.32 (03/17/11)
    TwonkyMedia 6.0.34 (06/24/11)
    • Based on 6.0 and 6.0.23 and 6.0.30 and 6.0.31RC6 and 6.0.32 and 6.0.34
    • ignoredir should finally work
    • pictures on WD client should be full screen now
    • better performance (again)
    • NSLU2 version should work now
    • Flash Interface
    • aggregation of TMS and WMC servers
    • auto update for PC versions
    • file system eventing support for MAC
    • time seek support for MPEG, WMA and WMV content
    • active connections info on status page
    • wpl playlists can contain URLs to Internet content (radio, pictures, video)
    • can now handle albumart art that has the same file name as a music or video file, but file extension is jpg,
      e.g. mymovie.mpg can have albumart file mymovie.jpg (make sure than the scanner filter is set to video only)
      Changes:
    • Improved URLs with fixed schema for scaling
    • Improved playlist handling, enabled upload of wpl playlists
    • I completely redraw the add-on :
    • fixed: Server takes 100% CPU on certain MPEG2 files
    • fixed: VIERA PAL model can't playback mpeg2
    • fixed: TwonkyMedia no longer starts on Raidsonic ICY Box
    • fixed: Deleting metadata results in D.E.L.E.T.E. entry
    • fixed: No video except WMV is playing on XBOX
    • fixed: MediaFeeds issue on WHS release
      • twonky share is removed properly
      • Nothing stored in /var
      • New option in frontview to delete and rebuild twonky database*
        • Use standard Twonky rescan button to pick up newly added media, but use this new Frontview button if you need to rebuild the database (helpful if Twonky crash or rescan doesn't pick up tag/artwork changes made to existing media). The standard Twonky rebuild button does not delete the previous database correctly (leaving lots of redundant files on your NAS); the new Frontview button completely deletes and rebuilds the database
      • you can access twonkymedia files and use custom trees (share is Twonkyedia)
  • Installation Notes:
    Please remove previous version before installing this one
    Port used is 9000
    / is show as / for searching
    I add in config
    twonky.inidisablelocalssdp=1
    to to prevent Twonky from advertising it self as 127.0.0.1 :
    if not working : To mask the loop back address, you can send an RPC call with the NAS's IP address (e.g. call: http://192.168.1.5:9000/rpc/set_option?ip=192.168.1.5) if your nas IP is 192.168.1.5
  • Screenshots:
what's new in 6.0.1
New in version 6.0.1:
+ new ini file option to limit the number of concurrent createObject operations. By default set to "upnpuploadlimit=0", which means unlimited as before.
+ new filter options m,p,v to supress one content type on a shared location
Changes:
o for Sony Bravia TV the server can no longer place the UI in the right subtree on the naviagtion as there is no way to detect where the UI of the TV is
o added more metadata properties for PVR support
o added upnp:artist role=composer metadata
o added pv:friendlyname as a property to be used in views
o added pv:lastPlaybackPosition as a property to be used by CPs for follow me scenarios
o always add mkv as video and mka as audio, never add a mkv as video even if server can not find the video part
o added: client adaptation for Sony VGF-CP1
Bug fixes:
- fixed: video thumbnails for XBOX
- fixed: broken language files, the word 'yes' was unreadable on the web config pages
- fixed: on aggregating videos from 4.x servers the album is now set to the friendly name of the server
- fixed: album art only shown for specific containers and not for all containers
- fixed: transcoding.db fixed to set NTSC as default MPEG target (has been no target before)
- fixed: react faster on aggregation server settings changes, display initial ammount of content on servers
- fixed: MacOS installer is not properly setting the system default language
- fixed: MacOS installer Japanese version shows English text
- fixed: Thumbnail support for video files on XBox
- fixed: iTunes playlist import
- fixed: album art for videos (folder.jpg) not scaled
- fixed: Twonky crashes when system is out of memory
what's new in 6.0.23
beside a number of smaller fixes, we mainly worked on performance improvements on the file scanner and browse responses.
6.0.23 Release notes:
- performance improvements when scanning files and on Browse responses
- fixed some issues with clients not displaying the right JPEG resolution in full screen or as thumbnail
6.0.30 Release Note
    Changes
  • added "Nokia Home Music" to clients.db
  • On language change a database rebuild is no longer necessary
  • Added mobile view to selectable views
  • Renamed "simple default navigation" to "classic media navigation"
  • Renamed "advanced default navigation" to "advanced media navigation"
  • INI file can now accept mobile and folder view as default setting
    Bug Fixes
  • : LPCM files are not working on PS3
  • : Duplicate content is displayed on enabling Aggregation.
  • : Reposition forward and backward is not working in case of WMA file on NETGEAR MP101
  • : Toshiba REGZA TV Cannot Play Any JPEG Contents except for JPEG_SM
  • : Thumnail view for gif files are not displayed while pulling the content from the server using WDTV live
  • : Sony Bravia Photos : Update 'protocolinfo' for JPEG_TN content.
  • : Json feed has broken links and thumbnails for online items
  • : Cleanup of navigation tree does not always work as expected
  • : Manual Rescan not working when scantime set to '0'
  • : Thumbnail view of JPEG files are not available on Samsung TV
  • : Pause/Resume is not working on Regza
  • : TwonkyServer reduces the resolution of some photos displayed on Denon receivers
  • : TwonkyServer can handle only 128 simultaneous CreateObject actions, which turned out to be too little
  • : Failure to find embedded albumart for a MP3 file with id3 v2.4.0 metadata (v2.3.0 works)
  • : Improve subtitle support for Samsung TVs
  • : Content name is not displayed properly if we use underscore in Wav files.
  • : Failure to send albumart for a MP3 file with embedded BMP
  • : Send default album art as fallback if embedded or external album art can not be sent
  • : Maxitems configuration property is ignored in some setups
  • : Add support for embedded albumart in MP3 files using id3 v2.4.0 metadata
  • : Several problems with duplicate detection
ProSupport for Business
