horim80
Aug 04, 2011Guide
UDP 514 port open for remote logging on syslogd . HELP!
Hi, I want to remote logging on readynas. So I did below, ReadyNAS-PRO:/# vim /etc/init.d/sysklogd # then I've added below line for receive log from remote device. SYSLOGD="-r -m 0" ...
CharlesLaCour
Aug 04, 2011Aspirant
If you added the "SYSLOGD="-r -m 0" before the line "test ! -r /etc/default/syslogd || . /etc/default/syslogd" the SYSLOGD far able was redefined.
You should edit the file "/etc/default/syslogd" and modify the definition of SYSLOGD in there.
