horim80
Aug 04, 2011Guide
UDP 514 port open for remote logging on syslogd . HELP!
Hi, I want to remote logging on readynas. So I did below, ReadyNAS-PRO:/# vim /etc/init.d/sysklogd # then I've added below line for receive log from remote device. SYSLOGD="-r -m 0" ...
horim80
Aug 04, 2011Guide
CharlesLaCour wrote: If you added the "SYSLOGD="-r -m 0" before the line "test ! -r /etc/default/syslogd || . /etc/default/syslogd" the SYSLOGD far able was redefined.
You should edit the file "/etc/default/syslogd" and modify the definition of SYSLOGD in there.
I also added "SYSLOGD="-r -m 0" to "/etc/default/syslogd" as you said but it doesn't work either.. :(
#! /bin/sh
# /etc/init.d/sysklogd: start the system log daemon.
SYSLOGD="-r -m 0"
PATH=/bin:/usr/bin:/sbin:/usr/sbin
pidfile=/var/run/syslogd.pid
binpath=/sbin/syslogd
test -x $binpath || exit 0
create_xconsole()
if [ ! -e /dev/xconsole ]; then
mknod -m 640 /dev/xconsole p
else
chmod 0640 /dev/xconsole
fi
chown root:adm /dev/xconsole
running()
# No pidfile, probably no daemon present
if [ ! -f $pidfile ]
then
return 1
fi
pid=`cat $pidfile`
# No pid, probably no daemon present
if [ -z "$pid" ]
then
return 1
fi
if [ ! -d /proc/$pid ]
then
return 1
fi
cmd=`cat /proc/$pid/cmdline | tr "\000" "\n"|head -n 1`
# No syslogd?
if [ "$cmd" != "$binpath" ]
then
return 1
fi
return 0
case "$1" in
start)
echo -n "Starting system log daemon: syslogd"
create_xconsole
start-stop-daemon --start --quiet --exec $binpath -- $SYSLOGD
echo "."
stop)
echo -n "Stopping system log daemon: syslogd"
start-stop-daemon --stop --quiet --exec $binpath --pidfile $pidfile
echo "."
reload|force-reload)
echo -n "Reloading system log daemon: syslogd"
start-stop-daemon --stop --quiet --signal 1 --exec $binpath --pidfile $pidfile
echo "."
restart)
echo -n "Restarting system log daemon: syslogd"
sleep 1
echo "."
reload-or-restart)
if running
then
else
fi
echo "."
echo "Usage: /etc/init.d/sysklogd {start|stop|reload|restart|force-reload|reload-or-restart}"
exit 1
esac
exit 0
# Top configuration file for syslogd
# Full documentation of possible arguments are found in the manpage
# syslogd(8).
# For remote UDP logging use SYSLOGD="-r"
SYSLOGD="-r -m 0"
Any advice?
