horim80
Aug 04, 2011Guide
UDP 514 port open for remote logging on syslogd . HELP!
Hi, I want to remote logging on readynas. So I did below, ReadyNAS-PRO:/# vim /etc/init.d/sysklogd # then I've added below line for receive log from remote device. SYSLOGD="-r -m 0" ...
horim80
Aug 04, 2011Guide
I have question to you.
udp 514 port still open after reboot the NAS?
I configured the NAS completely same as you.
I restart the syslogd then udp 514 port opened. yes it works at this time.
but it stop work after I reboot the NAS. udp 514 is not opened.
This is problem..
This is problem..
