horim80
Aug 04, 2011Guide
UDP 514 port open for remote logging on syslogd . HELP!
Hi, I want to remote logging on readynas. So I did below, ReadyNAS-PRO:/# vim /etc/init.d/sysklogd # then I've added below line for receive log from remote device. SYSLOGD="-r -m 0" ...
burokio
Mar 25, 2012Aspirant
Have you ever found a solution to this problem? I am having exactly the same issue, remote logging does not work after reboot. If i look at the list of processes after reboot I see that syslogd was started without the -r switch. After I manually restart it (sysklogd restart) - it starts with -r switch and remote loging works as expected. I've made exactly the same changes to /etc/init.d/sysklogd as shown in the first post.
