Vannareddy
Feb 15, 2021Aspirant
unable see backups
Hi, Could someone help me, I have NAS 526x I could see Backup is getting completed but unable to see the backups. when i right click on shared folders-->recover, I Could see only snapshots but ...
Feb 15, 2021Guru - Experienced User
Recover is only for snapshots. You can restore the backup(s) by reversing the direction of the backup jobs (switching source and destination).
Are you backing up to USB drives? Or over the network?
If USB, then what disk format did you choose? You should pick a format that you can read on one of your PCs.
- VannareddyFeb 16, 2021Aspirant
Hi Stephen,
Thanks for the reply, I have tried by reversing the direction of the backup, however just it tries to copy whateer the data is available in the NAS storage, I dont see the backups date wise.
I am using network to retrive the Data.
Also it would be great help, if you provide me the steps to copy the old backup to other drive by means of USB or Network.
Regqards,
Vanna Reddy
- StephenBFeb 16, 2021Guru - Experienced User
Normally you just switch the source and destinations.
Can you post the backup settings you are using now?
- VannareddyFeb 25, 2021Aspirant
Here is the logs and and backup settings.
Backup Job Name: Share2
Backup Job Type: Incremental
Protocol: cifs
Backup Source: [remote:cifs]///35.16.10.5/Engineering2
Backup Destination: [Engineering2]/
Backup Start Time: Thu Feb 25 2021 4:24:00
Backup Finish Time: Thu Feb 25 2021 4:40:17
Backup Status: SuccessSource is windows 2012 server
Destination NAS Storage Engineering2 (created shared folder)
when I reverse the Job, it copies only the current data, but I need to view the old backups.
Vanna Reddy
