budda1
Dec 17, 2012Aspirant
USB to UART Bridge VCP Drivers for CP210x
I've just begun looking at using my ReadyNAS Pro 6 as a potential home automation controller for the Z-Wave devices dotted around my home. I have an Aeon Labs Z-Stick S2 controller connected to my ...
ratep2001
Feb 10, 2014Aspirant
Has somebody solved this problem of installing CP210x driver? I want to connect ReadyNAS Duo v2 to Davis Vantage Pro2 weather station via Davis Weatherlink USB logger, which seems to use this chip. Inspecting with "lsusb" command via SSH I can see Cygnal Integrated Products etc. being connected to USB, but checking with "dmesg" I cannot see any /dev/ttyUSBx device mounted, only a message that a USB device is connected on Bus 3, device nr.3 or something similar.
I found some instructions for installing this driver and compiling it from source code for the particular Linux kernel, but I cannot install the "build-essential" for the particular debian distrubution, and I get the same error message that "build" is not existing although I can see it on the particular path.
Any clue about how to proceed?
