budda1
Dec 17, 2012Aspirant
USB to UART Bridge VCP Drivers for CP210x
I've just begun looking at using my ReadyNAS Pro 6 as a potential home automation controller for the Z-Wave devices dotted around my home. I have an Aeon Labs Z-Stick S2 controller connected to my ...
Ki_Adi_Mundi
Feb 11, 2014NETGEAR Employee Retired
budda wrote: I've had a crack at attempting a compile directly on the ReadyNAS Pro. Didn't get far.
Installed apt-get make along with the dev packages mentioned in the other getting started thread.
copied the correct makefile for the kernel in usecp ./Makefile26 ./Makefilethen attempted:# make
make -C /lib/modules/2.6.37.6.RNx86_64.2.4/build -I /root/cp210x-3.1.0/cp210x M=/root/cp210x-3.1.0/cp210x modules
make: *** /lib/modules/2.6.37.6.RNx86_64.2.4/build: No such file or directory. Stop.
make: *** [modules] Error 2
I can see 'build' is actually a symlink in the /lib/modules/.../ folder build -> /calzone/raidiator-x86/source/linux-x86-2.6
What is /calzone/raidiator-x86/source/linux-x86-2.6 because it doesn't exist?!
I'm out of my area of knowledge already :(
I think download the 4.2.x GPL source code and make a symlink to the kerne source can fix the above issue. But not sure what will happen after that. Do you want to try?
