budda1
Dec 17, 2012Aspirant
USB to UART Bridge VCP Drivers for CP210x
I've just begun looking at using my ReadyNAS Pro 6 as a potential home automation controller for the Z-Wave devices dotted around my home. I have an Aeon Labs Z-Stick S2 controller connected to my ...
kyle08
Sep 07, 2014Aspirant
Hi all,
After a few hours of search, here is my share for installing cp210x for ReadyNas 104 with os 6.1.8 => Arm architecture.
All the steps of iamthemitch http://www.readynas.com/forum/viewtopic.php?f=35&t=68537&p=433189#p418890 worked but (as I am a newbie) I did not apply the arm difference ride away .
So, follow those steps and change ARCH=x86_64 by ARCH=arm !
I heve been blocked when doing the
by having
So int the .conf file I commented the line
FYI no need to build the cp210x drivers before.
If you want to use "Homeseer" software, don't select the "Aeon Labs Aeotec Z-Stick" in the dropdown list of the "Controller management" area but the "Generic Serial Controller" instead.
Best regards.
make ARCH=arm
by having
make: arm-mv7-linux-gnueabi-gcc: Command not found
CHK include/linux/version.h
CHK include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
CC kernel/bounds.s
/bin/sh: 1: arm-mv7-linux-gnueabi-gcc: not found
make[1]: *** [kernel/bounds.s] Error 127
make: *** [prepare0] Error 2
CONFIG_CROSS_COMPILE="arm-mv7-linux-gnueabi-
Best regards.
