shardie
Jun 11, 2018Aspirant
uTorrent for ReadyNas 2120 x86
Does anyone know if there is a uTorrent app for the ReadyNAS 2120 or x86 NAS? I can only find one for the ARM cpu NAS's.
Jun 11, 2018Guru - Experienced User
I think you got this backwards - the uTorrent app on https://apps.readynas.com is only for x86.
Your 2120 is ARM, you can install Transmission on it.
shardie
I just realised I made that mistake - thanks, hehe. I tried Transmittion and it would download any torrents. Then I tried uTorrent on my Mac with the same torrent files and downloaded them immediately at full speed. I also didnt see a scheduler in Transmission.
- StephenBJun 11, 2018Guru - Experienced User
If you are comfortable using the linux command line, you could manually install uTorrent on the RN2120. If you do that, you want to make sure you install it onto the data volume, and make sure it's folders are also on the data volume. The OS partition is only 4 GB, and bad things can happen if it gets too full.
Or use uTorrent on your 2100 of course.
