horim80
Nov 21, 2013Guide
Virtualbox on OS6 NAS
Hi all, I know that it's possible to install VirtualBox on legacy x86 NAS. What about OS6? Does anyone knows how to install VirtualBox on OS6? Thanks.
cmassey
Mar 19, 2016Guide
### Upgrading NAS to 6.4.2 ###
### Upgrading VirtualBox ###
### to 5.0.16 ###
Download to NAS /data/VirtualBox:
http://download.virtualbox.org/virtualbox/5.0.16/
*Oracle_VM_VirtualBox_Extension_Pack-5.0.16.vbox-extpack
*VBoxGuestAdditions_5.0.16.iso
*virtualbox-5.0_5.0.16-105871-Debian-wheezy_amd64.deb
http://kb.netgear.com/app/answers/detail/a_id/2649/~/gpl-open-source-code-for-programmers
*ReadyNASOS_V6.4.2_WW_src.zip
## Installation of NAS update
Either manual or auto install ReadyNAS Update 6.4.2
## Cleanup
SSH to NAS
# ** Removing the symbolic link to the old kernel files for OS 6.2.4 (or 6.2.3)
cd /usr/src
rm linux-3.0.101-0.46
# ** Removing the linux-3.0.101-0.46 directory for OS 6.2.4
rm -rf /data/.apps/linux-3.0.101-0.46
# Cleanup VirtualBox directory
cd /data/VirtualBox
rm ReadyNASOS_V6.2.3_WW_src.zip
rm Oracle_VM_VirtualBox_Extension_Pack-4.3.26-98988.vbox-extpack
rm VBoxGuestAdditions_4.3.26.iso
rm virtualbox-4.3_4.3.26-98988~Debian~wheezy_amd64.deb
rm -rf tmp ## This should only be the extracted version of ReadyNASOS_V6.2.3_WW_src.zip
## Extract and copy kernel files
mkdir tmp
mv ReadyNASOS_V6.4.2_WW_src.zip tmp
cd tmp
unzip ReadyNASOS_V6.4.2_WW_src.zip
cp -rp linux-4.1.16-x86_64/ /data/.apps
ln -s /data/.apps/linux-4.1.16-x86_64 /usr/src/linux-4.1.16-x86_64
## Installation kernel files
apt-get update
** apt-get install build-essential ** You should be able to skip this step but I did it out of habit
export KERN_DIR=/usr/src/linux-4.1.16-x86_64
cd /usr/src/linux-4.1.16-x86_64
cp /data/VirtualBox/tmp/linux-4.1.16-x86_64/arch/x86/configs/defconfig.x86 /usr/src/linux-4.1.16-x86_64/.config
## ** Check kernel install options and modules
apt-get install bc
make menuconfig
make ARCH=x86_64
make modules_install ARCH=x86_64
## Uninstall VirtualBox 4.3
dpkg -r virtualbox-4.3
## Install VirtualBox 5.0.16
dpkg -i virtualbox-5.0_5.0.16-105871-Debian-wheezy_amd64.deb
sudo /sbin/rcvboxdrv setup
VBoxManage extpack uninstall "Oracle VM VirtualBox Extension Pack"
VBoxManage extpack install Oracle_VM_VirtualBox_Extension_Pack-5.0.16.vbox-extpack
- ChiffaNeMar 23, 2016Tutor
Followed the updated procedure and it seems everything actually worked!
sudo /sbin/rcvboxdrv setup - failed as sudo was not found but I'm not sure it actually is needed, dpkg seems to have installed everything.
Ok, spend the whole afternoon trying to make it work and failing.
It seems to start and work in the background, but when I try to connect via phpvirtualbox it fails, says access denied. I created the user vbox and made him a home directory, added to groub vboxusers and edited the /etc/default/virtualbox to run under him.
Also, interestingly, I can't find the /etc/init.d/vboxweb-service all of the internet is referring to.
- ChiffaNeMar 24, 2016Tutor
Finally got it working - had to disable vbox authentication:
su vbox VBoxManage setproperty websrvauthlibrary null
