horim80
Nov 21, 2013Guide
Virtualbox on OS6 NAS
Hi all, I know that it's possible to install VirtualBox on legacy x86 NAS. What about OS6? Does anyone knows how to install VirtualBox on OS6? Thanks.
cmassey
Apr 25, 2015Guide
The update 6.2.3 broke VirtualBox due to the kernel upgrade.
So far I've experienced a couple of issues.
1. This file is corrupts (missing the end) from the Netgear download site -->ReadyNASOS_V6.2.3_WW_src.zip
2. When trying to install the kernel it fails
I changed the permissions on scripts/basic/fixdep
then received
I decided to rollback to 6.2.2 and now
So I seem to be left in no mans land, I haven't really had enough time to look into it in detail yet but this is . Anyone have some ideas?
HOSTCC scripts/kconfig/conf.o
/bin/sh: 1: scripts/basic/fixdep: Permission denied
make[1]: *** [scripts/kconfig/conf.o] Error 126
make: *** [menuconfig] Error 2
then received
*** Unable to find the ncurses libraries or the
*** required header files.
*** 'make menuconfig' requires the ncurses libraries.
*** Install ncurses (ncurses-devel) and try again.
make[1]: *** [scripts/kconfig/dochecklxdialog] Error 1
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
build-essential : Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: g++ (>= 4:4.4.3) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
